In the table, the time range for SUA-001-2330 is from 2025-04-24 06:52:09 to 2025-04-25 23:59:59.000, but the actual timeline ends only at 2025-04-24 10:06:20, which is the start time of SUA-001-2331 column, this is obviously incorrect.
How to set the SUA-001-2330 end timeline to 2025-04-25 23:59:59.000?
Grafana version:11.6.1
The table view like behind
The timeline like behind
zillaer:
Step 1: Make each timeline label unique per row
If you have duplicate labels (like multiple rows with SUA-001-2330), Grafana merges or splits them.
Modify your PostgreSQL query like this:
SELECT
atime,
btime,
CONCAT(device_id, ' ', atime) AS label
FROM your_table
This will make the label like SUA-001-2330 2025-04-24 06:52:09, so Grafana treats each as a separate block.
Step 2: Update panel settings
In the right-side panel settings :
Turn off Merge equal consecutive values
Set Connect null values → Never
Set Show values → Always
Optional: Adjust Row height, Fill opacity, and Line width as needed
Step 3: Transformations in Grafana
In the Transformations tab :
Keep your current Convert field type
Add Organize fields :
Keep only: Atime, Btime, label
(Optional) Rename label to something meaningful like Status
