What Grafana version and what operating system are you using? Grafana 9.0.7 on a windows server 2019
What are you trying to achieve? When comparing the table data in the table view and to what the time serie is plotting, the time serie has added 2 seconds to every data point and interpolated a new Y-axis value.
I’m querying a postgre 12 server and the query looks like this:
SELECT
timedate AS “time”,
“Value”
FROM steril_tt_01
Here is 3 screenshots of what is happening:
As you can see in the pictures: the table data at 09:44:55 should be 6, but in the plotted time series graph the time is 09:44:57 and the value is now 10
So my question is this a bug or have anyone else seen the same issues and solved it? Have I done something incorrect in my procedure?
