I am facing an issue with Grafana Table global time range changes are not reflecting and always display whole data queried and applied with latest time stamp.
(component_counter_total{application="$application", componentClass=“abc”, status=“start”})
Thanks,
Vijay
I think the community has the best chance of helping if you can share either: A screenshot of your data as it appears in the table visualization. Or your raw unformatted data from the inspect drawer
Also, please try to follow the topic template. The community does not even know what version of Grafana you are running. Grafana develops very rapidly, and this is critical information
