9.5.19 (Hosted on Azure) -
Trying to use stat widget to show availability of the service. -
Writing a kql-M query to calculate the availability. -
What happened?
The stat says 100%, but the graph shows a dip. -
If I select “Table view” in the stat widget, for few hours it shows the availability as 99.7. Seems like when it sums all the availability in the time series, its rounding up to 100. I was expecting the actual value and round it up. -
No errors,
Stat widget discrepancy
The table view.
shows few hours it was at 99.9.
