Hi
My configruation is like this:
- Grafana 6.6.1
- Datasource: Simple JSON
- Database: Oracle OCI
The connection between Grafana and Oracle OCI works, because I have ohter panels that shows data out of my DB.
One of my panels shows the gender count in a department.
The field value shows ‘Total’ instead the ‘M’ or ‘F’.
These are not actual data that you see.
This is the JSON that is behind the panel
[{ "columns": [{ "text": "Gender", "type": "string" }, { "text": "Total", "type": "number" } ], "rows": [["M", 1], ["F", 5]], "type": "table" } ]
Kind Regards
Olivier
