- What is your Grafana version?
8.4.5 - Are you using Grafana Cloud or self-hosted Grafana?
self hosted - List the datasource associated with the alert
mssql
Display multiple values in a Stat plugin -
using 2 mssql sources and 1 Expression -
What happened?
When using a select query as alias Stat plugin overrides it with Value -
That Stat plugin would respect my query alias
