Start the grafana service with other user and report an error
Hello,gentlemen
There was an error when I installed and configured Grafana with tar package and started it. However, I switched to another directory to start, but this problem did not appear. Why is this? How to solve it
What was expected to happen?
    grafana 8.0.3
    start with other user in root dir success
    su operator /bin/bash -c ‘nohup /iotp/env/grafana/installed/bin/grafana-server --pidfile=/iotp/env/grafana/installed/run/grafana-server.pid --config=/iotp/env/grafana/installed/conf/grafana.ini --homepath /iotp/env/grafana/installed cfg:default.paths.provisioning=/iotp/env/grafana/installed/conf/provisioning cfg:default.paths.data=/iotp/data/env/grafana cfg:default.paths.logs=/iotp/env/grafana/installed/log cfg:default.paths.plugins=/iotp/env/grafana/installed/plugins cfg:default.server.http_port=21300 &’
  • What happened?
    start grafana failed
    start grafana success
    the error log
    panic: error getting work directory: stat .: permission denied
goroutine 1 [running]:
gopkg.in/macaron%2ev1.init.1()
/root/go/pkg/mod/gopkg.in/macaron.v1@v1.4.0/macaron.go:317 +0x110
