Grafana will only start manually , running the service will fail
hi,
running the grafana with command:
grafana-server -config /etc/grafana/grafana.ini -homepath /usr/share/grafana
will work great , but when i run from
systemctl start grafana-server
, service will not start…
my conf file is located at : /etc/grafana/grafana.ini ,
and my data is in : /data/grafana/lib/grafana/
/data/grafana/log/grafana/
/data/grafana/run/grafana/grafana-server.pid
i tried changing the env file directly, and the init.d file, and whatever i could find,
i cant understand anything from the error , and when running the service , it won’t write to the log file, only writes to log when running manually, and then everything is OK.
any ideas ?
thanks
David .
found the issue,
it was a permission issue,
i have to give permissions on the pid folder.
thanks.
