Stacking groups within the bar chart
    v9.1.1
    In a Bar Graph I am displaying data from a PV system grouped by days ofver the course of a month.
    Some Bars represent incoming energy from different sources (PV and public network), others show consumption (Washing machine, Dryer, Lights, whatever).
I would like to have the bars stack in two groups so there is one bar that includes all sources stacked and one bar that show consumption by the individual devices for each day of the month.
    I was hoping there would be a similar mechanism to the Time Series Panel where stacking groups A.B,C can be applied in override properties, but that is not the case (yet?)
If this feature is not possible at the moment I think it would make a great addition to the bar graph panel
Welcome
What is your datasource and could you please provide sample data?
My datasource is influxDB.
I’m not sure how I can provide sample data so at first here are some screenshots of the panel I am working on at the moment:
There is a lot going on here, so I will try to narrow it down a bit:
Some data is based on simple counters (energy meters) that always increase so I used the queries shown in the picture to extract the difference of the value from one day to the next to get the amount that was generated/consumed for each day.
As you can see in the graph having many values to show for each day of the month results in narrow individual bars which looks a little confusing.
since some of these bars represent incoming energy while others represent outgoing energy it would be nice to group and stack them. So for example I might want to stack “Netzbezug” (Energy received from the network) on top of “PV production” (Energy produced by the solar panels) to form a bar that shows all incoming energy.
Another stack could be “Verbrauch” (Energy consumed) and “Einspeisung” (Energy overhead that was returned to the public network).
In this special case the stack of incoming energy would be the same height as the stack of consumed/exported energy.
Heres a little drawing of what I would hope the result to look like.
I think a good solution from a usability perspective would be to not only allow stacking to be turned on or off (or 100%) but allow to assign stacking groups to queries.
So in this example I would assign Netzbezug and PV Produktion to Stacking Group A and Verbrauch and Einspeisung to Stacking Group B and the result would look like this:
Untitled-1
+1. I really want to see that feature implemented!
@janfribogar This is possible. What is your datasource? Please provide your data sample as csv
date,metric,value
2022-11-08 11:09:00,temp,33
2022-11-08  11:09:00,pressure,133
etc
What I want to achieve is what @Ierwin said. I have this queries:
A:
SELECT sum(“value”) FROM “solar_KWh” WHERE $timeFilter GROUP BY time($__interval) fill(null) tz(‘Europe/Madrid’)
B:
SELECT sum(“value”) FROM “export_KWh” WHERE $timeFilter GROUP BY time($__interval) fill(null) tz(‘Europe/Madrid’)
C:
SELECT sum(“value”) FROM “load_KWh” WHERE $timeFilter GROUP BY time($__interval) fill(null) tz(‘Europe/Madrid’)
D:
SELECT sum(“value”) FROM “import_KWh” WHERE $timeFilter GROUP BY time($__interval) fill(null) tz(‘Europe/Madrid’)
E:
SELECT sum(“value”) FROM “load_auto_KWh” WHERE $timeFilter GROUP BY time($__interval) fill(null) tz(‘Europe/Madrid’)
I want to stack A and B in one bar and C, D and E in another bar.
Hi all,
I was looking for this feature for a while. It would be great to have this implemented or solved somehow :+1:
@yosiasz do you have any update on this topic? Thank you for your support :slight_smile:
You can use “Stacking: normal” and “Bar alignment: after” as default for the panel and override this for all PV-earnings with “Bar alignment: before”. This way the consumption is on one stacked bar and the PV-earnings on the other next to it.
I have not yet figured out how to make the bars slim so they do not overlap with the bar for the next day.
Thank you @Lythie !
You are using the time series visualization for generating the bar chart. I was able to reproduce your solution and to achieve the plot you showed. As you said the downside of this is an overlap of the bars of the chart.
I am looking for a solution right in the bar chart visualization. The bar chart visualization is the one I would naturally use to generate a bar chart.
I would also really like to see stacked bar graphs being natively supported in Grafana.
Although not the best example, AWS’ Cost Explorer demonstrates what I would like best, having a breakdown of costs by month, in a stacked bar graph:
It’s not exactly what was asked for, but if you decide to use after and center as bar alignments it comes pretty close:
Hi there,
long time gone, did anyone catch up this topic? I’m very interessted in getting such grouped stacks.
Best Regard, Jürgen
I created a feature request in GitHub for this: Stacking groups within the bar chart · Issue #86868 · grafana/grafana · GitHub .
If you are interested in this feature, please support the feature request :slight_smile: .
Hi everyone,
I just came across this thread because I was looking for a solution to exactly this problem. As there obviously is no progress on the feature request (which is a real shame) I’ve been pondering over a workaround on basis of the bar chart since the solution with the time series has some nasty drawbacks (e.g. with showing the data when hovering over the data points).
I actually came to this solution:
Aggregate the data series you do not want to be stacked on slightly different time points. So, in my case I have several data series with daily data points each timestamped on 1 a.m.. One of these series contains the sum of all the other series per day and therefore should not be stacked in the bar chart. By shifting all data points of the sum series by 1h to 2 p.m. forces Grafana to show this data series in a separate bar. See this screenshot:
Maybe this workaround is working for you, too … as long as Grafana is not have the capabilties.
