100% stacked bar chart
How would I achieve this graph?
this is the query i am using
select Region, column1, column2 from table
and the data it returns
is this possible in Grafana? since this is not a time series, i’m not sure… but i wanted to ask anyway, maybe someone knows something…
Hi @sederfo
I would explore using the new categorical bar chart:
You can try mocking this data yourself by adding and using the TestData DB datasource that ships with Grafana
Thank you, yes, this is the solution! I figured I was using an older version of Graphana but now I updated to v8.1.4 and I can see the Stacking option! :smiley:
