Grafana v10.0.3 with ClickHouse, Windows 10 -
Display a pareto chart displaying fail runs for various test stations -
Creating a pareto chart each bar consisting of different partial bars each representing the fail rate on the various test stations (if applicable) -
What happened?
A bar is missing on some configurations -
All bars are displayed and no gaps between the bars where one is expected. -
No errors
I created a SQL query to get the required data and formatted it as “Time series”. When the pareto chart is displayed it shows the following result:
Each color is representing one single station. If a color is missing in one bar it means that no fail runs occurred at this station for the test.
At the third position a complete bar is missing. When I change the number of displayed bars it suddenly appears.
When running the query with a normal table output all data is correct and present. Also the ordering by the overall fail rate descending is executed correctly.
What am I doing wrong?
Moreover the bars not correctly displayed in the desired order. Bars with a higher overall fail rate are placed more right although I expect them more to the left.
Are there other ordering options in the panel configuration besides a “ORDER BY” in the SQL statement?
