Stackdriver agent Metrics filtering by instance name rather than ID on GCP compute instances
Hey,
In the past when i have used stackdriver as a data source i have been able to filter by metric.label.instance_name, However when using Agent as the service i am only able to filter by resource.label.instance_id is there a workaround for this or method to show the instance name alongside the ID as i can see in the stackdriver documentation
agent.googleapis.com/memory/percent_used is the metric in question.
Thanks
I have the same question, can anyone help please? Thank you.
I have the same question. Did anyone figure it out?
