Hi, if you hover over the Info icon in the Alias field you’ll get the following description:
Alias replacement variables:
- {{metric}}
- {{stat}}
- {{namespace}}
- {{region}}
- {{period}}
- {{YOUR_DIMENSION_NAME}}
So I guess you should be able to input something there to distinguish between instances, like {{InstanceId}} maybe?
The question is about cloudwatch - NOT influxdb
okaay. Thanks got it.
