I use sqlte-datasource plugin and grab data from the DB using query.
Data is there. I can see it in the table view, but not in the Graph view. It says Unable to graph data Switch to table view.
Can someone help me ?
You need to cast your date to timestamps format.
Good Luck
Yes resolved it ! thanks you
