i have multiple series from a sqlite database but i don’t know how to change the displayed name
Actually all the curve have the same Name “Rssi”
Grafana v 11.6.1
Sqlite Plugin : 3.5.0 (2024-03–08)
Thanks a lot for your help
Franck
Grafana v 11.6.1
Franck
Hello @kroa38,
Did this solution work for you? If it’s working, kindly mark it as the solution.
What does it show when you click the Table View button?
You need to specify time metric and value for it to work well in grafana
is Src_Name your metric for the rssi value?
please provide some sample data as csv here like
rssi,time,Src_Name
-33.5,2025-04-29 14:25:23.825030+00:00,289803572
or provide a script for generating your data
Hello yosiasz,
Thanks you it works !
i have change my queries as you mention and added override for each serie.
i can now differentiate each series.
