I am using 10.4.19,windows -
I am trying to split a table in panel in to multiple tables.
I need to split a table which is populated using promethes as a datasource.I need to split some columns in to two tables so that can be uded for my requirement.
Is it possible to split the table derived from a metric? If possible what are the transformations Needs to be used.Can you please help me in this.
Thank you
I am looking to split according to columns.If a table contains 5 columns. Two columns should be under one table and other two columns under other table
Hi @nawinchappidi,
You can resolve your issue by following the steps outlined below.
Step 1. Start the Prometheus server.
Step 2. Integrate Prometheus as a data source in Grafana.
Step 3. Write a PromQL query to fetch the data in a table format with multiple column.
nalytics_summaries_rollup_duration_seconds_count{job="grafana"}
or analytics_summaries_buffer_size{job="grafana"}
or analytics_summaries_rollup_duration_seconds_sum{job="grafana"}
or analytics_summaries_rollup_previous_time{job="grafana"}
or deprecated_flags_inuse_total{job="grafana"}
Step 4. Apply the transformation to organize the data into columns by selecting or deselecting the appropriate labels.
Final ouput :
) ) )Note: This solution requires two panels for implementation.
Hi @infofcc3 Thanks for the reply.
My requirement is to divide the table according to columns in the same panel where the prometheus metric table populated.Is that possible?
Hi @infofcc3 , Any inputs for the above Query
you could try some html using Business Text Grafana plugin
