- Grafana 10.4.2, Linux
- Create table which shows CPU and Memory Utilization per cluster/datasource
Table panel → Mixed Datasource → Prometheus query
queries below -
label_replace(100- min_over_time(avg by (region) (rate(node_cpu_seconds_total{mode=“idle”}[1m]))[15d:]) * 100, “Cluster”, “mke5.devfg.com”, “”, “”)
label_replace(max_over_time( ( 100 * (sum by (region) (node_memory_MemTotal_bytes) - sum by (region) (node_memory_MemAvailable_bytes))/ sum by (region) (node_memory_MemTotal_bytes))[15d:]), “Cluster”, “mke5.devfg.com”, “”, “”)
added transformation → inner join via cluster label, merge row/series, organize fields
What happened?
- Shows multiple columns per datasource, instead of only 2 columns
