Sorting wildcard series
v8.0.3
I have multiple series coming from a single data source, and Id like to be able to control the order of these series in the graph, as my graph is stacked. I've only got 2 series, and, by default, they are alphabetical. Id like to reverse this, although knowing how to do an arbitrary order would also be useful.
I was hoping that I`d be able to do something about this in the panel options rather than the query, but I couldn’t find anything in either Graph (old) or Time Series
My current query (to Graphite) is:
aliasByNode(sumSeriesWithWildcards(exclude(a.b.c.d.*.*.g, 'pending'), 4), 4)
This is giving series labels based on the * that is in the “f” position, in alphabetical order.
I tried adding a sortByName function around this:
sortByName(aliasByNode(sumSeriesWithWildcards(exclude(a.b.c.d.*.*.g, 'pending'), 4), 4), true)
I tried with both true and false as the parameter.
I found this documentation on Graphite:
https://graphite.readthedocs.io/en/latest/functions.html#graphite.render.functions.sortByName
But the function in Grafana only seems to take a single parameter. Changing it doesn’t seem to make any difference.
  • What happened?
Nothing changed
I was hoping to be able to have my “B” series be on the bottom of the stacked graph and the “A” series be on the top.
See above
No errors
