I display Zabbix data in a graph panel, using the “Series” mode.
The displayed data is not sorted.
Is it possible to sort them alphabetically for example in this mode?
Always in the same panel graph, actually, if I add an additional series, it will be added to the suite following the first one. Can we imagine using an aggregation if the alias is exactly the same ?
Aggregation for several queries may be tricky because plugin works with each query separately. Sorting by alias may be a good feature request for plugin. Can you try to construct query which covers all needed metrics (using regex)?
I use a regex to select all the items I want to display. Then, I use the replaceAlias function to change the alias.
It would be great to be able to sort the items in alpha order of their alias.
It would be even more brilliant if we could group them by alias to make a sum for example items with the same alias.
How can i help you ?
Thank you very much for your job.
