I’m new to grafana and I am having a problem creating a graph from the data provided from a influxdb database.
I’m using GitHub - custom-components/sensor.owlintuition: A set of sensors to integrate the OWL Intuition devices network to gather data from my Owl intuition PV sensor
My solar panels provide periodic readings of the watts being generated and these are fed into an influxdb database over the course of the day.
Sometimes these readings are low, when there are clouds and then later, high in full sunlight.
I wish to combine the present, and the last readings together of electricity being generated, thus providing a rising graph indicating the cumulative wattage being generated, or at least, generated over the passing of a day from 00:00 to 23:59 hours.
I am using grafana to plot the results but sofar I’ve not managed to get a result.
1 I would like to see all readings summed from between 00:00hr to 23:59hr
2 I need 1 end of day figure graphed
I’m beginning to think that this may need to be a Influxdb operation or a grafana one, but I don’t know!
