Latest, Linux. -
Taking the momentary watts data I’m inputting, and create a bar graph that converts to kWh per day (so I can see daily energy usage). -
Setup a bar graph using the sum() and math(/360000) setup. -
What happened?
Graph shows very wrong values per day, and the few days of data I have seem offset (i.e. I’m not seeing any data at all for today, but I’m getting a bar on the day before I started my influx database). If I set the bar graph to “today” time scale I get the correct tally. -
Expected to get a bar graph showing the correct KWH per day. -
SELECT sum(“Watts”) / 360000 FROM “autogen”.“iotawatt” WHERE (“sensor”::tag = ‘solar’) AND time >= 1682924400000ms and time <= 1685394119999ms GROUP BY time(1d) fill(null)
