I’m using Grafana Agent 0.40.3 to gather SNMP data from various devices.
Everything works fine for devices without a community string (or let’s say the default public string)
This would be my config:
integrations:
snmp:
enabled: true
snmp_targets:
- name: ncr1
address: 192.168.0.34
module: if_mib
- name: k1521
address: 192.168.204.251
module: if_mib
The device 192.168.204.251 works without issues;
The device 192.168.0.34 would need a community string. But I can not find where to put it
This page says there was a breaking change; but somehow the example got rid of the community string as well.
And the normal documentation about the SNMP exporter integration does not show a community string. Also I can not find an example anywhere that shows the auths section in the snmp_config block.
Would greatly appreciate any hint!
