I have had problem with configuration grafana cloud agent. It’s possible collect snmp metrics from agent-config.yaml. I don’t understand where i can add MIB/OID to grafana_agent. In which section ?
Hi @it7b710 !
If you are using something like the SNMP Prometheus Exporter then the Grafana Agent should be able to discover and scrape the SNMP metrics. Here is an overview about the Grafana Agent.
Also, there is an SNMP integration for Grafana Cloud available here. To install this integration, navigate to the Connections section of your hosted Grafana environment to generate a customized install script and configuration file.
See also Connect your data to Grafana Cloud for all of the options for working with your data in Grafana Cloud.
