Is it possible to setup a snapshot server (like raintank) for intranet use? The idea would be to create snapshots via API from the “real” server and publish them on a different, still not a public server? This would solve some security issues that I’m thinking.
I can’t seem to be able to google much on that even as the grafana configuration file clearly seems to enable that…
I’m not sure I understand. I’m asking what do you have to do to enable a server to become a snapshot server that can present a snapshot like Raintank.
I have looked at the grafana.ini settings where you can set the url to export snapshots TO… How do the Grafana server and raintank communicate ? The API doesn’t seem to have a method or at least I didn’t find one. Only a setting to publish it externally (to the url set in grafana.ini).
OK, so no special trick needed for the server. So I guess then just http access between them is needed. Thanks!
But we’re still struggling to create a working snapshot via the API… So bare with me again:
If I have a dashboard A and use the UI and select say two template variables color and form to be black and round, the data is fetched and when I create a snapshot via UI, the url will give the exact same dashboard but you can’t do any more color or form selections after that as the snapshot contains also the data for the selections. (You can see that with the API GET snapshots function).
But how do you re-create the exact same snapshot via the API? We’ve tried and the result is a snapshot that has the templating menus active and the snapshot attempts to access the data source which doesn’t work if you’re not authenticated. So it really doesn’t work the same way as the one’s done with the UI which doesn’t require any credentials to the server. It just works with the url.
If this is getting too long winded, we can do this via e-mail as well…
The Snapshot API doesn’t provide a way to pass dashboard variable values (or a time range) and have Grafana resolve them server-side when creating a snapshot. Instead, it expects the fully populated dashboard payload, including the snapshot data, which is what the Grafana UI prepares before calling the API.
The official documentation states:
“When creating a snapshot using the API, you have to provide the full dashboard payload including the snapshot data. This endpoint is designed for the Grafana UI.”
So, if you need a snapshot for a specific set of variable values, the Snapshot API expects a fully populated dashboard payload. In practice, the Grafana UI prepares this payload before calling the Snapshot API.
