Snapshot API : how to get the data?
What is the method to make a snapshot via the API and include the data please ?
I can not find any information on the subject.
Should I collect the data via a query on the data source (in my case Graphite) then include the result in the “snapshotData” section of the JSON sent to Grafana?
Is there a simpler solution?
Thank you
This is not possible, the data is captured by the frontend so you would have to replicate what all the panel & data sources do (issue metric queries etc)
Thank you for your fast reply Torkel.
“Forging” a snapshot can represent a lot of work. It should be great if the API could make a snapshot from an existing dashboard.
Did you plan to extend the API for make this possible ?
It would not be possible without running the frontend in the backend via a headless browser to capture the snapshot. So possible not tricky, maybe next year when we work on reporting features.
+1 for this feature. Will you please provide updates for this feature? Will it to be a plug-in? We need this feature, please advise.
+1 for this feature too
+1 for this feature as well
+1 for this feature!!
+1 for this feature :fire:
For anyone looking for a temp solution you can find it here.
