SMTP failed to send test alert
  • Version 10.2.2 (commit: 161e3cac5075540918e3a39004f2364ad104d5bb, branch: HEAD)
    setup email notifications off of alerts triggered in grafana
    setting up grafana.ini file correctly or any other means I may be missing from my current setup
  • What happened?
    When sending a test email I receive an immediate response “SMTP not configured, check you grafana.ini”
    an email to be sent to the recipient
 #################################### SMTP / Emailing ##########################
  [smtp]
  enabled = True
  host = localhost:25
  ;user =
  ;password =
  ;cert_file =
  ;key_file =
  skip_verify = True
  from_address = admin@grafana.localhost
  from_name = Grafana
  ;ehlo_identity = dashboard.example.com
  startTLS_policy = NoStartTLS
  [emails]
  ;welcome_email_on_sign_up = false
  ;templates_pattern = emails/*.html, emails/*.txt
  ;content_types = text/html
    Pop up notification stating “SMTP not configured, check you grafana.ini”
Try to use:
enabled = true
Found the issue. The grafana.ini is not being used by our version. Instead its a default.ini that is being used by our vendors product. I was editing the wrong ini.
