Hi Guys,
is there an option to ‘smooth’ easily graphs in grafana?
I don’t want this ‘data jumps’ for a more beautiful line.
In excel there is “smoothed line” checkbox - I’m looking vor something like this.
Thank you very much!
No there is no smoothing function. Well it depends on your time series database, some have functions that can smooth out series (like a moving average)
Seems like you have a step function enabled.
If you select “Edit”, then second bullet at the right: disable “Staircase”.
As you have a reasonable amount of measurements you might get a smoother view, still you will see some ups and downs, especially in the amber curve.
