Grafana v9.3.4 - MacOS -
What happened?
I am getting my data through Athena-plugin and with a SQL query. I created a time series graph for my data, but I get a straight line in some of my graphs. I checked, the line doesn’t have any data or label attached to it.
Here are some examples. See the highlighted lines.
Example SQL query:
SELECT
date_trunc('hour', from_unixtime(w_datetime/1000)) as w_datetime,
sum(metric) as total_metric
FROM table
WHERE object = 'purple'
GROUP BY date_trunc('hour', from_unixtime(datetime/1000)) as w_datetime,
ORDER BY w_datetime
