v9.5.2 -
Greetings all,
Thank you much in advance
I am visualizing the real time data from influxdb in grafana dashboards. In my influxdb there are around 10 tags which has many fields. I am trying to create small box in a dashboards with short name of the tag and trying to make coloring like when there is data coming to influx and grafana then the box is green and when suppose i have no real time data the i would like to have box turned red.
i am using flux query which i can have access to the data from each tag. But i have no exact idea how can i achieve my goal. -
What happened?
I am looking for any plugin or dashboard design may be to have box with letter which changes the color with data and no data
