I would like to display IT Services from Zabbix with Siglestat but Grafana shows wrong value.
I have set up in Zabbix uptime (Mon-Fri, 07-17) and downtime (17-00). I showed IT services as Table and I noticed that in Downtime shows 100 and Uptime shows 0. In Uptime it assumes that it doesn’t work in the whole hour. In addition, it takes values from around the clock to calculate values, not just Uptime.
For example:
It shows that in 6:00 and 7:00 service is ok but not true.
Singlestat shows 50% and it should be 0 (the service is not working)
Where is the problem?
