Trying to create a memory singestat panel, I’d like the gauge to show dynamically the amount free but it seems to be full (stuck on green) any ideas?
Using InfluxDB and Telegraf
Here is the metrics snippet:
You need to set min/max values which you find on another tab (maybe display tab?) but it’s where you enable the gauge.
Marcus
