Threshold in percent and 'max' gauge from value in database
I have configured a Singlestat panel which get information on how much disk space is used on a server from an InfluxDB. However I’m wondering if it is somehow possible to set the thresholds to a percentage instead of a static number?
And also if it is possible to set the max value in a gauge as a variable?
Since the disk can be expanded I would have to manually reconfigure the panel for the new values everytime.
Is any of this possible?
I had a similar use case and the workaround that i followed is as below
  1. write 3 metrics to influxdb, quota, used_quota and used_percent
  2. create a panel based on used_percent and a collapsed graph with quota & used_quota metrics for details and trend.
    Bala
Thanks, I will try that.
@patricf, I need to do the same thing and am curious where you landed with this. We’re you able to use sources from your db for the thresholds in the gauge?
