Is it possible to create a Singlestat Gauge where the free space is displayed in percent?
I have the following performance values from the storage in my influxdb:
Value = current free space in MB
MAX = the total size of the memory area.
Regards
Hermann
dcech
2
Yes, the exact syntax depends on the TSDB you are using.
For InfluxDB you can use math in your SELECT:
SELECT (total - used) / total * 100 FROM ...
For Graphite you’d want to check out the asPercent and diffSeries functions:
asPercent(diffSeries(total, used), total)
thanks for your reply.
Here my Select:
SELECT "(max - value) / max *100" FROM "check_vmware_esx" WHERE "service" = 'VMware Datastore' AND "metric" = 'Storage1-MS'
But i cannot see a Value only “N/A”
Hmm. is there a mistake in the SELECT Statement?
Regards
Hermann
dcech
4
Why do you have quotes around the expression? It should be:
SELECT (max - value) / max * 100 FROM check_vmware_esx WHERE service = 'VMware Datastore' AND metric = 'Storage1-MS'
