What happened?
When I use Singlestat math plugin and select 30 days in dropdown it not render correct value. So I am cliking the plugin edit option and just clicking on the Query text box the plugin refreshes and renders correct value.
What was expected to happen?
When I select the 30 days or 15 days the value should automatically displays in the singlestat math plugin , I should go to edit options and refresh it .
Steps to reproduce the problem:
- Create a single stat math and give query formulas .
- Select from drop down as 2 days or last 24 hours → correct value will come.
- Select from drop down as last 15 days or 30 days → value will not come.
- Click >Edit in the single stat math plugin and just click in the query box and display box value refreshes and populate.
Version numbers (grafana, prometheus, graphite, plugins, operating system, etc.):
Grafana - 6.7.3 and 7.1.0
prometheus - 2.7.1
