SimpleJson table panel not showing data
Hello all,
I am running Grafana v7 with latest SimpleJson plugin. I am using the table response only so I have three endpoints, / , /query and /search.
/ returns 200
/query returns a json array as suggested (columns, rows and type:table)
/search returns an empty array [{}]
The test connection works on the test connection page
However when I add in the panel, it reports as query error 404. No data.
I am able to curl the three endpoints without issues. Is there anyway to troubleshoot what could be wrong? There is not much logging and I couldn’t tell what might be missing.
Any suggestion is appreciated.
thanks
ben
Have you turned on debug logging?
arh true. let me try
We recently added a Troubleshooting section to the Grafana documentation. Take a look, there might be some ideas to help you further narrow down this issue.
We are closing this topic since there have been no further responses from the author, and it referrers to Grafana v7, which is no longer supported as of the time of this reply.
