i am on Grafana v10.1.5
in the Temperature Gauges i want to see the last updated value date.
this way i can see if the temperature is from recent or from a long time ago.
in this screenshot i put 1 in using paint:
can this be done and how should i do it ?
This could maybe be done using Dynamic Text plugin. I don’t know if the Stats plugin does this
grant2
3
How about just selecting All Fields?
it does something odd when doing that
here it is with Dynamic Text where you have a bit more control
it does show time/date but all the same while the temp sensors are not updates at the same time.
i entered the content code, i cannot get the query correct.
