A have some time based measurements and they are working very well, I can show on Grafana different field values. But how to show a tag value depending on another field value?
| tag_key | field1 | field2 |
| A | 211 | 10 |
| B | 154 | 20 |
| C | 123 | 20 |
| D | 343 | 10 |
| E | 343 | 10 |
| F | 367 | 10 |
| G | 343 | 20 |
| H | 435 | 25 |
For example. I want to show the values of field1 only if field2 values are 10 at the same time. Ist that possible with Grafana? I didn’t found any possibility. Datasource is influxdb. Thank you
