Hello.
I am at a loss with this.
Example:
measurement: responsetime
tag key-value pair of server=1.2.3.4
field key-value pair of ttr=100
In Influx I can write a query:
SELECT COUNT(ttr) FROM timeouts WHERE ttr >= 100 GROUP BY server
This will return how often each server IP had a time to respond over 100ms.
It seems impossible in Grafana as it would look like this:
A FROM default responsetime WHERE {“Here I can only select tags, but not fields”}
SELECT COUNT(ttr) {“Here are lots of options. Math is not working and I see no comparators”}
GROUP BY tag(server)
So am I doing something wrong, or misunderstanding something, or is this simply not possible?
