- 12.3.3
- Change the time range for one panel to the last 12 full months. If today is 18. February 2026, I want the following labels on the x-axis: 2025-02 - 2026-02.
- I’ve tried several different approaches, including
Relative time,Time shiftand PromQL aggregation methods on the Panel. In many cases all I got wasNo data. - I tested if the data was still there when changing the dashboard’s time range but got similar results.
- I’ve also tested the same thing with InfluxDB, which worked just fine. We would like to use Mimir though.
What happened?
- The main issue is that the data seems to vanish when changing the dashboard’s time range:
Last 7 days- data from today and yesterday is shown -
Last 30 days- data from yesterday is shown -
Last 6 months- both data from today and yesterday is missing
- I was expecting to see today’s and yesterday’s data when selecting
Last 6 monthsas it is the case when selectingLast 7 days. - Can someone please explain how to use
Relative timeandTime shift?
- I could not find any proper explanation of how to use
Relative timeandTime shift.
