Shift time / data relation for one graph
I do have two graphs in a panel which are using the same influx source. It is a solar prediction. The correlation is peak_watts at a specific time.
I need this dataset for two graphs in one panel: one is PV and the other one is thermic. The data is exactly the same, but because of different mounting directions on the roof the data for thermic starts 2 hours later than the one for PV.
Is it possible to get two graphs in one panel from the same data where one is only moved two hours right (later)? Y-values are exactly the same, but x must be shifted 2 hours to the right. And - important - I do not want to shift the range. I want a graph where each timestamp is 7200 seconds higher, for each data point.
