9 -
Configure Grafana in Azure to monitor/access more than 1 subscription at a time -
We created a new monitor in Azure but you have to select a subscription and the setup only allows the selection of a single subscription -
What happened?
We can view/monitor details in 1 subscription only.
The ability to select other subscriptions or setup the monitor to view multiple subscriptions to access all our data without having to build and get charged for individual monitors
- Can you copy/paste the configuration(s) that you are having problems with?
No config issue, just question on whether this is a limitation?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No
- Did you follow any online instructions? If so, what is the URL?
Could not find any documentation on this
