Multiple azure data sources/subscriptions
Can we have access to multiple azure data sources/subscriptions and create dashboard from single Grafana cloud subscription? Will Grafana Cloud Pro suffice for that?
  • What happened?
Hi @aalam
Yes, you can add multiple instances of the same datasource to the same Grafana Cloud instance/account. You’re good to go!
