I’m trying to use the status panel addon however it isn’t updating. I have read the solution at: Status Panel does not update
however I cannot find how to implement the fix. I can see the alias in the usual panel configuration menu but I cannot work out what they mean by the query alias. that the setting corresponds to
what I need to know is: how do I set up the query alias that they are referring to?
