For example i have a var that is used for a panel to repeat, and that further pushes to a detail panel via a link with the var being passed. That var is a query to the influxdb to populate it:
show tag values from dellsc_san_disks with key="hostname"
With results like: array1 - 111111 array2 - 22222 array3 - 33333. Thats a format of “Name - SerialNumber”
On the detail dashboard i have to use a different datasource (mssql) that requires only the SN, rather than the name being passed. So i would like to have a var named SN on that dashboard that could be just the SN part of the name and would be defined on dashboard load. Thats why i thought if i could use the regex of the var value and set that to a new var named SN the details dashboard would have it available to use with no user input. Other wise i think i am left forcing the user to select the SN on the details dashboard.
