Hi everyone ,
I just upgraded my grafana server on my respberrypi to the latest 8.5.0 version…
previously i had the 8.4.7
now, grafana won’t start anymore…
i get a big non-understandable (for me) error…
i have 2 raspberry (1x RPI2B and 1x RPI4)
both installation now are broken…
if anyone can help… ;
thanks a lot !
Eric.
On the Raspberry Pi 2 i get:
raspberrypi:~ $ grafana-server
runtime: unexpected return pc for github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10 called from 0x9
stack: frame={sp:0x4fa3c34, fp:0x4fa3c5c} stack=[0x4f84000,0x4fa4000)
0x04fa3bb4: 0x00000000 0x04fa3bc0 0x00000000 0x05092460
0x04fa3bc4: 0x0002c194 <runtime.newobject+0x0000002c> 0x04922900 0x00000180 0x00000170
0x04fa3bd4: 0x048000f0 0x00000040 0x002c2038 <net/http.(*http2serverConn).sendWindowUpdate32+0x000000f0> 0x027f0100
0x04fa3be4: 0x76cef2a8 0x0000016c 0x04800100 0x00000000
0x04fa3bf4: 0x02478480 0x04312cd0 0x00000000 0x00000000
0x04fa3c04: 0x00000000 0x00000000 0x0007492c <runtime.sigpanic+0x000001e8> 0x02478480
0x04fa3c14: 0x04312cd0 0x02092c5c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000002c> 0x048000f0 0x022d9601
0x04fa3c24: 0x04922900 0x023bc5d8 0x048000f0 0x02092c5c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000002c>
0x04fa3c34: <0x00000009 0x050924b4 0x04971e40 0x04922900
0x04fa3c44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00054bb8 <runtime.(*consistentHeapStats).acquire+0x00000068> 0x00035d20 <runtime.(*mcache).refill+0x00000154>
0x04fa3c54: 0x048513ac 0x0000001d >0x0000001e 0x00000101
0x04fa3c64: 0x0000001e 0x00000000 0x0487e0bf 0x00000000
0x04fa3c74: 0x00000000 0x00000012 0x00000016 0x0000000b
0x04fa3c84: 0x0486fca0 0x0486fca4 0x0000001a 0x00033400 <runtime.findObject+0x00000058>
0x04fa3c94: 0x000396bc <runtime.SetFinalizer+0x00000064> 0x0003991c <runtime.SetFinalizer+0x000002c4> 0x00000001 0x00000012
0x04fa3ca4: 0x00000001 0x00000000 0x00000000 0x00000000
0x04fa3cb4: 0x00000000 0x00000000 0x00000000 0x00000000
0x04fa3cc4: 0x04810110 0x00000008 0x00000008 0x0236f380
0x04fa3cd4: 0x0261df30 0x00020138 <armCas64+0x00000000>
fatal error: unknown caller pc
runtime stack:
runtime.throw({0x28134c0, 0x11})
/usr/local/go/src/runtime/panic.go:1198 +0x5c
runtime.gentraceback(0x5858c, 0x4fa3c0c, 0x0, 0x48000f0, 0x0, 0x0, 0x7fffffff, 0x7e8d34b4, 0x0, 0x0)
/usr/local/go/src/runtime/traceback.go:274 +0x1540
runtime.addOneOpenDeferFrame.func1()
/usr/local/go/src/runtime/panic.go:751 +0x8c
runtime.systemstack()
/usr/local/go/src/runtime/asm_arm.s:318 +0x60
goroutine 1 [running, locked to thread]:
runtime.systemstack_switch()
/usr/local/go/src/runtime/asm_arm.s:275 +0x4 fp=0x4fa3b84 sp=0x4fa3b80 pc=0x90abc
runtime.addOneOpenDeferFrame(0x48000f0, 0x5858c, 0x4fa3c0c)
/usr/local/go/src/runtime/panic.go:750 +0x70 fp=0x4fa3ba0 sp=0x4fa3b84 pc=0x59bf8
panic({0x2478480, 0x4312cd0})
/usr/local/go/src/runtime/panic.go:998 +0xe8 fp=0x4fa3c0c sp=0x4fa3ba0 pc=0x5aa28
runtime.panicmem()
/usr/local/go/src/runtime/panic.go:221 +0x4c fp=0x4fa3c18 sp=0x4fa3c0c pc=0x5858c
runtime.sigpanic()
/usr/local/go/src/runtime/signal_unix.go:735 +0x1e8 fp=0x4fa3c30 sp=0x4fa3c18 pc=0x7492c
github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10()
/drone/src/pkg/services/alerting/notifiers/pushover.go:97 +0x2c fp=0x4fa3c5c sp=0x4fa3c34 pc=0x2092c5c
goroutine 114 [select]:
go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x4b46780)
/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:243 +0xf4
go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x4b46780)
/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:111 +0x4c
created by go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor
/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:109 +0x1e8
goroutine 13 [select]:
go.opencensus.io/stats/view.(*worker).start(0x4b47140)
/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0
created by go.opencensus.io/stats/view.init.0
/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x64
goroutine 146 [chan receive]:
github.com/golang/glog.(*loggingT).flushDaemon(0x4588760)
/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:882 +0x70
created by github.com/golang/glog.init.0
/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:410 +0x214
On the Raspberry Pi 4 the error is different:
raspberrypi4:~ $ grafana-server
unexpected fault address 0x27f6b5a
fatal error: fault
[signal SIGSEGV: segmentation violation code=0x1 addr=0x27f6b5a pc=0x27f6b5a]
runtime.throw({0x27eb2a9, 0x5})
/usr/local/go/src/runtime/panic.go:1198 +0x5c fp=0x545bc18 sp=0x545bc04 pc=0x5b244
runtime.sigpanic()
/usr/local/go/src/runtime/signal_unix.go:742 +0x1d0 fp=0x545bc30 sp=0x545bc18 pc=0x74914
stack: frame={sp:0x545bc34, fp:0x545bc5c} stack=[0x543c000,0x545c000)
0x0545bbb4: 0x0005d1a0 <runtime.gwrite+0x00000034> 0x04668d52 0x029efeac 0x00000001
0x0545bbc4: 0x00000001 0x00000000 0x0005da4c <runtime.printstring+0x00000060> 0x00000002
0x0545bbd4: 0x029efeac 0x00000001 0x00000001 0x00000000
0x0545bbe4: 0x00000000 0x0005b450 <runtime.fatalthrow+0x00000044> 0x0005b244 <runtime.throw+0x0000005c> 0x0545bbf4
0x0545bbf4: 0x0005b468 <runtime.fatalthrow.func1+0x00000000> 0x04c000f0 0x0005b244 <runtime.throw+0x0000005c> 0x0545bc04
0x0545bc04: 0x00074914 <runtime.sigpanic+0x000001d0> 0x0545bc0c 0x0005b25c <runtime.throw.func1+0x00000000> 0x027eb2a9
0x0545bc14: 0x00000005 0x02092c5c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000002c> 0x027eb2a9 0x00000005
0x0545bc24: 0x04e63080 0x027f6b5a 0x04c000f0 0x02092c5c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000002c>
0x0545bc34: <0x00000009 0x05239e18 0x04e03f00 0x04e63080
0x0545bc44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00054bb8 <runtime.(*consistentHeapStats).acquire+0x00000068> 0x00035d20 <runtime.(*mcache).refill+0x00000154>
0x0545bc54: 0x04c568ac 0x0000002b >0x0000002c 0x00000101
0x0545bc64: 0x0000002c 0x00000000 0x04caa0bf 0x00000000
0x0545bc74: 0x00000000 0x00000013 0x00000016 0x0000000b
0x0545bc84: 0x04c6eca0 0x04c6eca4 0x0000001a 0x00033400 <runtime.findObject+0x00000058>
0x0545bc94: 0x000396bc <runtime.SetFinalizer+0x00000064> 0x0003991c <runtime.SetFinalizer+0x000002c4> 0x00000001 0x00000013
0x0545bca4: 0x00000001 0x00000000 0x00000000 0x00000000
0x0545bcb4: 0x00000000 0x00000000 0x00000000 0x00000000
0x0545bcc4: 0x04ca00f8 0x00000008 0x00000008 0x0236f380
0x0545bcd4: 0x0261df30 0x00020138 <armCas64+0x00000000>
/drone/src/pkg/services/alerting/notifiers/pushover.go:97 +0x2c fp=0x545bc5c sp=0x545bc34 pc=0x2092c5c
goroutine 100 [select]:
go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x4cd49c0)
go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x4cd49c0)
goroutine 77 [select]:
go.opencensus.io/stats/view.(*worker).start(0x51e8ba0)
goroutine 81 [chan receive]:
i just do a rollback of the raspberrypi4 grafana server to 8.4.7 and now it is running again…
so, something is wrong with the latest 8.5.0
i use repo: https://packages.grafana.com/oss/deb stable InRelease
Same problem here on Raspi 4…
same here:
install procedure:
wget https://dl.grafana.com/oss/release/grafana_8.5.0_armhf.deb
sudo dpkg -i grafana_8.5.0_armhf.deb
relevant syslog entries (part1, due to size limitation):
systemd[1]: Started Grafana instance.
kernel: [87125.912581] Unhandled prefetch abort: unknown 1 (0x001) at 0x027f6b5a
grafana-server[30606]: SIGBUS: bus error
kernel: [87126.724895] Unhandled prefetch abort: unknown 1 (0x001) at 0x027f6b5a
grafana-server[30606]: PC=0x27f6b5a m=0 sigcode=0
grafana-server[30606]: goroutine 1 [running, locked to thread]:
grafana-server[30606]: runtime: unknown pc 0x27f6b5a
grafana-server[30606]: stack: frame={sp:0x6c1bc34, fp:0x0} stack=[0x6bfc000,0x6c1c000)
grafana-server[30606]: 0x06c1bbb4: 0x00000000 0x06c1bbd0 0x00000000 0x0651cfc0
grafana-server[30606]: 0x06c1bbc4: 0x0002c194 <runtime.newobject+0x0000002c> 0x06652600 0x00000180 0x00000170
grafana-server[30606]: 0x06c1bbd4: 0x022d96a8 0x00000040 0x002c2038 <net/http.(*http2serverConn).sendWindowUpdate32+0x000000f0> 0x027f0100
grafana-server[30606]: 0x06c1bbe4: 0x6596f5a8 0x0000016c 0x00000170 0x76d532e0
grafana-server[30606]: 0x06c1bbf4: 0x00000180 0x045896c8 0x06652600 0x00000000
grafana-server[30606]: 0x06c1bc04: 0x24595180 0x02092c4c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000001c> 0x00000170 0x022d96a8
grafana-server[30606]: 0x06c1bc14: 0x00000001 0x06652600 0x0006d184 <runtime.doInit+0x00000114> 0x022d96a8
grafana-server[30606]: 0x06c1bc24: 0x06652600 0x023bc5d8 0x06601f80 0x027f6b5a
grafana-server[30606]: 0x06c1bc34: <0x00000009 0x0651d020 0x06595140 0x06652600
grafana-server[30606]: 0x06c1bc44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00054bb8 <runtime.(*consistentHeapStats).acquire+0x00000068> 0x00035d20 <runtime.(*mcache).refill+0x00000154>
grafana-server[30606]: 0x06c1bc54: 0x06453dac 0x00000017 0x00000018 0x00000101
grafana-server[30606]: 0x06c1bc64: 0x00555555 <google.golang.org/protobuf/internal/impl.newSingularConverter+0x00000e11> 0x065120ff 0x00000018 0x00000000
grafana-server[30606]: 0x06c1bc74: 0x00000000 0x00000018 0x00000016 0x0000000b
grafana-server[30606]: 0x06c1bc84: 0x00000002 0x0646aca4 0x0000001a 0x00033400 <runtime.findObject+0x00000058>
grafana-server[30606]: 0x06c1bc94: 0x00000008 0x00000019 0x00000001 0x00000019
grafana-server[30606]: 0x06c1bca4: 0x00000001 0x00000000 0x00000000 0x00000000
systemd[1]: grafana-server.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
grafana-server[30606]: goroutine 101 [select]:
grafana-server[30606]: go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x66567e0)
grafana-server[30606]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:243 +0xf4
grafana-server[30606]: go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x66567e0)
grafana-server[30606]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:111 +0x4c
grafana-server[30606]: created by go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor
grafana-server[30606]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:109 +0x1e8
grafana-server[30606]: goroutine 116 [select]:
grafana-server[30606]: go.opencensus.io/stats/view.(*worker).start(0x66d6000)
grafana-server[30606]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0
grafana-server[30606]: created by go.opencensus.io/stats/view.init.0
grafana-server[30606]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x64
grafana-server[30606]: goroutine 96 [chan receive]:
grafana-server[30606]: github.com/golang/glog.(*loggingT).flushDaemon(0x4588760)
systemd[1]: grafana-server.service: Failed with result 'exit-code'.
grafana-server[30606]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:882 +0x70
grafana-server[30606]: created by github.com/golang/glog.init.0
grafana-server[30606]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:410 +0x214
grafana-server[30606]: trap 0x0
grafana-server[30606]: error 0x1
grafana-server[30606]: oldmask 0x0
grafana-server[30606]: r0 0x6652600
grafana-server[30606]: r1 0x2f1624c
grafana-server[30606]: r2 0x6652600
grafana-server[30606]: r3 0x1
grafana-server[30606]: r4 0x6d184
grafana-server[30606]: r5 0x22d96a8
grafana-server[30606]: r6 0x6652600
grafana-server[30606]: r7 0x23bc5d8
grafana-server[30606]: r8 0x6601f80
grafana-server[30606]: r9 0x180
grafana-server[30606]: r10 0x64000f0
grafana-server[30606]: fp 0x466769c
grafana-server[30606]: ip 0x665277f
grafana-server[30606]: sp 0x6c1bc34
grafana-server[30606]: lr 0x2092c5c
grafana-server[30606]: pc 0x27f6b5a
grafana-server[30606]: cpsr 0x60000010
grafana-server[30606]: fault 0x0
systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 1.
grafana-server[30618]: SIGBUS: bus error
grafana-server[30618]: PC=0x27f6b5a m=0 sigcode=0
grafana-server[30618]: goroutine 1 [running, locked to thread]:
grafana-server[30618]: runtime: unknown pc 0x27f6b5a
grafana-server[30618]: stack: frame={sp:0x6fedc34, fp:0x0} stack=[0x6fce000,0x6fee000)
grafana-server[30618]: 0x06fedbb4: 0x00000000 0x06fedbd0 0x00000000 0x06a82700
grafana-server[30618]: 0x06fedbc4: 0x0002c194 <runtime.newobject+0x0000002c> 0x06e40780 0x00000180 0x00000170
grafana-server[30618]: 0x06fedbd4: 0x022d96a8 0x00000040 0x002c2038 <net/http.(*http2serverConn).sendWindowUpdate32+0x000000f0> 0x027f0100
grafana-server[30618]: 0x06fedbe4: 0x646c0e48 0x0000016c 0x00000170 0x76d28790
grafana-server[30618]: 0x06fedbf4: 0x00000180 0x045896c8 0x06e40780 0x00000000
grafana-server[30618]: 0x06fedc04: 0xe092ddc0 0x02092c4c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000001c> 0x00000170 0x022d96a8
grafana-server[30618]: 0x06fedc14: 0x00000001 0x06e40780 0x0006d184 <runtime.doInit+0x00000114> 0x022d96a8
grafana-server[30618]: 0x06fedc24: 0x06e40780 0x023bc5d8 0x06a08040 0x027f6b5a
grafana-server[30618]: 0x06fedc34: <0x00000009 0x06a82758 0x0692dd80 0x06e40780
grafana-server[30618]: 0x06fedc44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00000000 0x00000000
grafana-server[30618]: 0x06fedc54: 0x00000000 0x00000000 0x00000000 0x00000000
grafana-server[30618]: 0x06fedc64: 0x00555555 <google.golang.org/protobuf/internal/impl.newSingularConverter+0x00000e11> 0x068a213f 0x00000018 0x00000000
grafana-server[30618]: 0x06fedc74: 0x00000000 0x00000018 0x00000016 0x0000000b
grafana-server[30618]: 0x06fedc84: 0x00000002 0x0686aca4 0x0000001a 0x00033400 <runtime.findObject+0x00000058>
grafana-server[30618]: 0x06fedc94: 0x00000008 0x0000001a 0x00000001 0x0000001a
grafana-server[30618]: 0x06fedca4: 0x00000001 0x00000000 0x00000000 0x00000000
systemd[1]: Stopped Grafana instance.
grafana-server[30618]: goroutine 117 [select]:
grafana-server[30618]: go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x6b086c0)
grafana-server[30618]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:243 +0xf4
grafana-server[30618]: go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x6b086c0)
grafana-server[30618]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:111 +0x4c
grafana-server[30618]: created by go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor
grafana-server[30618]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:109 +0x1e8
grafana-server[30618]: goroutine 12 [select]:
grafana-server[30618]: go.opencensus.io/stats/view.(*worker).start(0x6ad09c0)
grafana-server[30618]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0
grafana-server[30618]: created by go.opencensus.io/stats/view.init.0
grafana-server[30618]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x64
grafana-server[30618]: goroutine 135 [chan receive]:
grafana-server[30618]: github.com/golang/glog.(*loggingT).flushDaemon(0x4588760)
grafana-server[30618]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:882 +0x70
grafana-server[30618]: created by github.com/golang/glog.init.0
grafana-server[30618]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:410 +0x214
grafana-server[30618]: trap 0x0
grafana-server[30618]: error 0x1
grafana-server[30618]: oldmask 0x0
grafana-server[30618]: r0 0x6e40780
grafana-server[30618]: r1 0x2f1624c
grafana-server[30618]: r2 0x6e40780
grafana-server[30618]: r3 0x1
grafana-server[30618]: r4 0x6d184
grafana-server[30618]: r5 0x22d96a8
grafana-server[30618]: r6 0x6e40780
grafana-server[30618]: r7 0x23bc5d8
grafana-server[30618]: r8 0x6a08040
grafana-server[30618]: r9 0x180
grafana-server[30618]: r10 0x68000f0
grafana-server[30618]: fp 0x466769c
grafana-server[30618]: ip 0x6e408ff
grafana-server[30618]: sp 0x6fedc34
grafana-server[30618]: lr 0x2092c5c
grafana-server[30618]: pc 0x27f6b5a
grafana-server[30618]: cpsr 0x60000010
grafana-server[30618]: fault 0x0
systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 2.
kernel: [87127.654566] Unhandled prefetch abort: unknown 1 (0x001) at 0x027f6b5a
grafana-server[30639]: SIGBUS: bus error
grafana-server[30639]: PC=0x27f6b5a m=0 sigcode=0
grafana-server[30639]: goroutine 1 [running, locked to thread]:
grafana-server[30639]: runtime: unknown pc 0x27f6b5a
grafana-server[30639]: stack: frame={sp:0x586dc34, fp:0x0} stack=[0x584e000,0x586e000)
grafana-server[30639]: 0x0586dbb4: 0x00000000 0x0586dbc0 0x00000000 0x050bb180
grafana-server[30639]: 0x0586dbc4: 0x0002c194 <runtime.newobject+0x0000002c> 0x0548e900 0x00000180 0x00000170
grafana-server[30639]: 0x0586dbd4: 0x022d96a8 0x00000040 0x002c2038 <net/http.(*http2serverConn).sendWindowUpdate32+0x000000f0> 0x027f0100
grafana-server[30639]: 0x0586dbe4: 0x64fc8620 0x0000016c 0x00000170 0x76d7f538
grafana-server[30639]: 0x0586dbf4: 0x00000180 0x045896c8 0x0548e900 0x00000000
grafana-server[30639]: 0x0586dc04: 0xc6042500 0x02092c4c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000001c> 0x00000170 0x022d96a8
grafana-server[30639]: 0x0586dc14: 0x00000001 0x0548e900 0x0006d184 <runtime.doInit+0x00000114> 0x022d96a8
grafana-server[30639]: 0x0586dc24: 0x0548e900 0x023bc5d8 0x050a0b80 0x027f6b5a
grafana-server[30639]: 0x0586dc34: <0x00000009 0x050bb1d8 0x05042300 0x0548e900
grafana-server[30639]: 0x0586dc44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00000000 0x00000000
grafana-server[30639]: 0x0586dc54: 0x00000000 0x00000000 0x00000000 0x00000000
grafana-server[30639]: 0x0586dc64: 0x00555555 <google.golang.org/protobuf/internal/impl.newSingularConverter+0x00000e11> 0x050a213f 0x00000018 0x00000000
grafana-server[30639]: 0x0586dc74: 0x00000000 0x00000018 0x00000016 0x0000000b
grafana-server[30639]: 0x0586dc84: 0x00000002 0x0506aca4 0x0000001a 0x00033400 <runtime.findObject+0x00000058>
grafana-server[30639]: 0x0586dc94: 0x00000008 0x00000014 0x00000001 0x00000014
grafana-server[30639]: 0x0586dca4: 0x00000001 0x00000000 0x00000000 0x00000000
grafana-server[30639]: goroutine 89 [select]:
relevant syslog entries (part2, due to size limitation):
grafana-server[30639]: go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x522f140)
grafana-server[30639]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:243 +0xf4
grafana-server[30639]: go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x522f140)
grafana-server[30639]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:111 +0x4c
grafana-server[30639]: created by go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor
grafana-server[30639]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:109 +0x1e8
grafana-server[30639]: goroutine 80 [select]:
grafana-server[30639]: go.opencensus.io/stats/view.(*worker).start(0x522f8c0)
grafana-server[30639]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0
grafana-server[30639]: created by go.opencensus.io/stats/view.init.0
grafana-server[30639]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x64
grafana-server[30639]: goroutine 134 [chan receive]:
grafana-server[30639]: github.com/golang/glog.(*loggingT).flushDaemon(0x4588760)
grafana-server[30639]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:882 +0x70
grafana-server[30639]: created by github.com/golang/glog.init.0
grafana-server[30639]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:410 +0x214
grafana-server[30639]: trap 0x0
grafana-server[30639]: error 0x1
grafana-server[30639]: oldmask 0x0
grafana-server[30639]: r0 0x548e900
grafana-server[30639]: r1 0x2f1624c
grafana-server[30639]: r2 0x548e900
grafana-server[30639]: r3 0x1
grafana-server[30639]: r4 0x6d184
grafana-server[30639]: r5 0x22d96a8
grafana-server[30639]: r6 0x548e900
grafana-server[30639]: r7 0x23bc5d8
grafana-server[30639]: r8 0x50a0b80
grafana-server[30639]: r9 0x180
grafana-server[30639]: r10 0x50000f0
grafana-server[30639]: fp 0x466769c
grafana-server[30639]: ip 0x548ea7f
grafana-server[30639]: sp 0x586dc34
grafana-server[30639]: lr 0x2092c5c
grafana-server[30639]: pc 0x27f6b5a
grafana-server[30639]: cpsr 0x60000010
grafana-server[30639]: fault 0x0
systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 3.
kernel: [87128.443909] Unhandled prefetch abort: unknown 1 (0x001) at 0x027f6b5a
grafana-server[30669]: SIGBUS: bus error
grafana-server[30669]: PC=0x27f6b5a m=0 sigcode=0
grafana-server[30669]: goroutine 1 [running, locked to thread]:
grafana-server[30669]: runtime: unknown pc 0x27f6b5a
grafana-server[30669]: stack: frame={sp:0x6c6dc34, fp:0x0} stack=[0x6c4e000,0x6c6e000)
grafana-server[30669]: 0x06c6dbb4: 0x00000000 0x06c6dbc0 0x00000000 0x066ece00
grafana-server[30669]: 0x06c6dbc4: 0x0002c194 <runtime.newobject+0x0000002c> 0x06724d80 0x00000180 0x00000170
grafana-server[30669]: 0x06c6dbd4: 0x022d96a8 0x00000040 0x002c2038 <net/http.(*http2serverConn).sendWindowUpdate32+0x000000f0> 0x027f0100
grafana-server[30669]: 0x06c6dbe4: 0x76d7e768 0x0000016c 0x00000170 0x76d74538
grafana-server[30669]: 0x06c6dbf4: 0x00000180 0x045896c8 0x06724d80 0x00000000
grafana-server[30669]: 0x06c6dc04: 0x71616200 0x02092c4c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000001c> 0x00000170 0x022d96a8
grafana-server[30669]: 0x06c6dc14: 0x00000001 0x06724d80 0x0006d184 <runtime.doInit+0x00000114> 0x022d96a8
grafana-server[30669]: 0x06c6dc24: 0x06724d80 0x023bc5d8 0x065993c0 0x027f6b5a
grafana-server[30669]: 0x06c6dc34: <0x00000009 0x066ece60 0x06616180 0x06724d80
grafana-server[30669]: 0x06c6dc44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00000000 0x00000000
grafana-server[30669]: 0x06c6dc54: 0x00000000 0x00000000 0x00000000 0x00000000
grafana-server[30669]: 0x06c6dc64: 0x00555555 <google.golang.org/protobuf/internal/impl.newSingularConverter+0x00000e11> 0x064a213f 0x00000018 0x00000000
grafana-server[30669]: 0x06c6dc74: 0x00000000 0x00000018 0x00000016 0x0000000b
grafana-server[30669]: 0x06c6dc84: 0x00000002 0x0646aca4 0x0000001a 0x00033400 <runtime.findObject+0x00000058>
grafana-server[30669]: 0x06c6dc94: 0x00000008 0x00000019 0x00000001 0x00000019
grafana-server[30669]: 0x06c6dca4: 0x00000001 0x00000000 0x00000000 0x00000000
grafana-server[30669]: goroutine 95 [select]:
grafana-server[30669]: go.opencensus.io/stats/view.(*worker).start(0x6721260)
grafana-server[30669]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0
grafana-server[30669]: created by go.opencensus.io/stats/view.init.0
grafana-server[30669]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x64
grafana-server[30669]: goroutine 119 [select]:
grafana-server[30669]: go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x6720360)
grafana-server[30669]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:243 +0xf4
grafana-server[30669]: go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x6720360)
grafana-server[30669]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:111 +0x4c
grafana-server[30669]: created by go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor
grafana-server[30669]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:109 +0x1e8
grafana-server[30669]: goroutine 125 [chan receive]:
grafana-server[30669]: github.com/golang/glog.(*loggingT).flushDaemon(0x4588760)
grafana-server[30669]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:882 +0x70
grafana-server[30669]: created by github.com/golang/glog.init.0
grafana-server[30669]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:410 +0x214
grafana-server[30669]: trap 0x0
grafana-server[30669]: error 0x1
grafana-server[30669]: oldmask 0x0
grafana-server[30669]: r0 0x6724d80
grafana-server[30669]: r1 0x2f1624c
grafana-server[30669]: r2 0x6724d80
grafana-server[30669]: r3 0x1
grafana-server[30669]: r4 0x6d184
grafana-server[30669]: r5 0x22d96a8
grafana-server[30669]: r6 0x6724d80
grafana-server[30669]: r7 0x23bc5d8
grafana-server[30669]: r8 0x65993c0
grafana-server[30669]: r9 0x180
grafana-server[30669]: r10 0x64000f0
grafana-server[30669]: fp 0x466769c
grafana-server[30669]: ip 0x6724eff
grafana-server[30669]: sp 0x6c6dc34
grafana-server[30669]: lr 0x2092c5c
grafana-server[30669]: pc 0x27f6b5a
grafana-server[30669]: cpsr 0x60000010
grafana-server[30669]: fault 0x0
systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 4.
kernel: [87129.191852] Unhandled prefetch abort: unknown 1 (0x001) at 0x027f6b5a
grafana-server[30689]: SIGBUS: bus error
grafana-server[30689]: PC=0x27f6b5a m=0 sigcode=0
grafana-server[30689]: goroutine 1 [running, locked to thread]:
grafana-server[30689]: runtime: unknown pc 0x27f6b5a
grafana-server[30689]: stack: frame={sp:0x6c6dc34, fp:0x0} stack=[0x6c4e000,0x6c6e000)
grafana-server[30689]: 0x06c6dbb4: 0x00000000 0x06c6dbc0 0x00000000 0x0671fc00
grafana-server[30689]: 0x06c6dbc4: 0x0002c194 <runtime.newobject+0x0000002c> 0x06743c80 0x00000180 0x00000170
grafana-server[30689]: 0x06c6dbd4: 0x022d96a8 0x00000040 0x002c2038 <net/http.(*http2serverConn).sendWindowUpdate32+0x000000f0> 0x027f0100
grafana-server[30689]: 0x06c6dbe4: 0x76d5ab68 0x0000016c 0x00000170 0x76d4f088
grafana-server[30689]: 0x06c6dbf4: 0x00000180 0x045896c8 0x06743c80 0x00000000
grafana-server[30689]: 0x06c6dc04: 0x0962fc00 0x02092c4c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000001c> 0x00000170 0x022d96a8
grafana-server[30689]: 0x06c6dc14: 0x00000001 0x06743c80 0x0006d184 <runtime.doInit+0x00000114> 0x022d96a8
grafana-server[30689]: 0x06c6dc24: 0x06743c80 0x023bc5d8 0x0659d240 0x027f6b5a
grafana-server[30689]: 0x06c6dc34: <0x00000009 0x0671fc58 0x0662fb80 0x06743c80
grafana-server[30689]: 0x06c6dc44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00000000 0x00000000
grafana-server[30689]: 0x06c6dc54: 0x00000000 0x00000000 0x00000000 0x00000000
grafana-server[30689]: 0x06c6dc64: 0x00555555 <google.golang.org/protobuf/internal/impl.newSingularConverter+0x00000e11> 0x0644213f 0x00000018 0x00000000
grafana-server[30689]: 0x06c6dc74: 0x00000000 0x00000018 0x00000016 0x0000000b
grafana-server[30689]: 0x06c6dc84: 0x00000002 0x0646fca4 0x0000001a 0x00033400 <runtime.findObject+0x00000058>
grafana-server[30689]: 0x06c6dc94: 0x00000008 0x00000019 0x00000001 0x00000019
grafana-server[30689]: 0x06c6dca4: 0x00000001 0x00000000 0x00000000 0x00000000
grafana-server[30689]: goroutine 105 [select]:
grafana-server[30689]: go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x66350e0)
grafana-server[30689]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:243 +0xf4
grafana-server[30689]: go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x66350e0)
grafana-server[30689]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:111 +0x4c
grafana-server[30689]: created by go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor
grafana-server[30689]: #011/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_span_processor.go:109 +0x1e8
grafana-server[30689]: goroutine 111 [select]:
grafana-server[30689]: go.opencensus.io/stats/view.(*worker).start(0x66354a0)
grafana-server[30689]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0
grafana-server[30689]: created by go.opencensus.io/stats/view.init.0
grafana-server[30689]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x64
grafana-server[30689]: goroutine 135 [chan receive]:
grafana-server[30689]: github.com/golang/glog.(*loggingT).flushDaemon(0x4588760)
grafana-server[30689]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:882 +0x70
grafana-server[30689]: created by github.com/golang/glog.init.0
grafana-server[30689]: #011/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23def4e6c14b/glog.go:410 +0x214
grafana-server[30689]: trap 0x0
grafana-server[30689]: error 0x1
grafana-server[30689]: oldmask 0x0
grafana-server[30689]: r0 0x6743c80
grafana-server[30689]: r1 0x2f1624c
grafana-server[30689]: r2 0x6743c80
grafana-server[30689]: r3 0x1
grafana-server[30689]: r4 0x6d184
grafana-server[30689]: r5 0x22d96a8
grafana-server[30689]: r6 0x6743c80
grafana-server[30689]: r7 0x23bc5d8
grafana-server[30689]: r8 0x659d240
grafana-server[30689]: r9 0x180
grafana-server[30689]: r10 0x64000f0
grafana-server[30689]: fp 0x466769c
grafana-server[30689]: ip 0x6743dff
grafana-server[30689]: sp 0x6c6dc34
grafana-server[30689]: lr 0x2092c5c
grafana-server[30689]: pc 0x27f6b5a
grafana-server[30689]: cpsr 0x60000010
grafana-server[30689]: fault 0x0
systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
systemd[1]: grafana-server.service: Start request repeated too quickly.
systemd[1]: Failed to start Grafana instance.
I have the same issue. Can I ask how did you do the rollback to the version 8.4.7?
i simply use:
sudo apt install grafana=8.4.7
This is doing the trick. Thank you.
same here, grafana-server 8.5.0 does not run on my Pi 4.
Rollback to 8.4.7 and all is good
pi@raspberrypidns:~ $ grafana-server
unexpected fault address 0x0
fatal error: fault
[signal SIGBUS: bus error code=0x1 addr=0x0 pc=0x27f6b5a]
/usr/local/go/src/runtime/panic.go:1198 +0x5c fp=0x5d2dc18 sp=0x5d2dc04 pc=0x5b244
runtime.sigpanic()
/usr/local/go/src/runtime/signal_unix.go:732 +0xac fp=0x5d2dc30 sp=0x5d2dc18 pc=0x747f0
stack: frame={sp:0x5d2dc34, fp:0x5d2dc5c} stack=[0x5d1e000,0x5d2e000)
Exactly same issue on 8.5.0, had to install old version again
Same here with a Raspberry PI 3B
SIGBUS: bus error
stack: frame={sp:0x6c8fc34, fp:0x0} stack=[0x6c80000,0x6c90000)
0x06c8fbb4: 0x00000000 0x06c8fbc0 0x00000000 0x06a84700
0x06c8fbc4: 0x0002c194 <runtime.newobject+0x0000002c> 0x06630900 0x000001800x00000170
0x06c8fbd4: 0x022d96a8 0x00000040 0x002c2038 <net/http.(*http2serverConn).sdWindowUpdate32+0x000000f0> 0x027f0100
0x06c8fbe4: 0x76d87378 0x0000016c 0x00000170 0x76d7a088
0x06c8fbf4: 0x00000180 0x045896c8 0x06630900 0x00000000
0x06c8fc04: 0x0c69bac0 0x02092c4c <github.com/grafana/grafana/pkg/services/arting/notifiers.init.10+0x0000001c> 0x00000170 0x022d96a8
0x06c8fc14: 0x00000001 0x06630900 0x0006d184 <runtime.doInit+0x00000114> 022d96a8
0x06c8fc24: 0x06630900 0x023bc5d8 0x068c0f00 0x027f6b5a
0x06c8fc34: <0x00000009 0x06a847bc 0x0669ba80 0x06630900
0x06c8fc44: 0x0006d0c4 <runtime.doInit+0x00000054> 0x0433c6b8 0x00054bb8 <rtime.(*consistentHeapStats).acquire+0x00000068> 0x00035d20 <runtime.(*mcache)efill+0x00000154>
0x06c8fc54: 0x064513ac 0x0000001d 0x0000001e 0x00000101
0x06c8fc64: 0x0000001e 0x00000000 0x0647e0bf 0x00000000
0x06c8fc74: 0x00000000 0x00000019 0x00000016 0x0000000b
0x06c8fc84: 0x0646fca0 0x0646fca4 0x0000001a 0x00033400 <runtime.findObjec0x00000058>
0x06c8fc94: 0x000396bc <runtime.SetFinalizer+0x00000064> 0x0003991c <runtimeetFinalizer+0x000002c4> 0x00000001 0x00000019
0x06c8fca4: 0x00000001 0x00000000 0x00000000 0x00000000
goroutine 81 [select]:
go.opentelemetry.io/otel/sdk/trace.(*batchSpanProcessor).processQueue(0x65249c
/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_an_processor.go:243 +0xf4
go.opentelemetry.io/otel/sdk/trace.NewBatchSpanProcessor.func1(0x65249c0)
/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_an_processor.go:111 +0x4c
/opt/drone/gomodcache/go.opentelemetry.io/otel/sdk@v1.0.0/trace/batch_an_processor.go:109 +0x1e8
goroutine 115 [select]:
go.opencensus.io/stats/view.(*worker).start(0x673df20)
/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:27+0xa0
/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:340x64
goroutine 122 [chan receive]:
/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23d4e6c14b/glog.go:882 +0x70
/opt/drone/gomodcache/github.com/golang/glog@v0.0.0-20160126235308-23d4e6c14b/glog.go:410 +0x214
me too.
/var/log/grafana $ grafana-server
fatal error: fault
/usr/local/go/src/runtime/panic.go:1198 +0x5c fp=0x549bc18 sp=0x549bc04 pc=0x5b244
runtime.sigpanic()
…etc…
After rolling back to a previous version you might want to put the package “on hold” to prevent that during the next update it is replaced with the current version (which does not run):
sudo apt-mark hold grafana
kayd
April 25, 2022, 8:13pm
#14
Same here on Raspi 3B+, Pi OS Bullseye:
$ grafana-server
SIGBUS: bus error
Same here. Raspberry4 running buster. Downgrade fixed the issue.
chphe
April 26, 2022, 12:51pm
#16
The above also is reported as a bug: grafana-server doesn't start after recent update to 8.5.0 on openhabian · Issue #48130 · grafana/grafana · GitHub
I experienced the same problem. Currently there is no fix. Although it seems to work on the 64 bit version of Raspberry Pi OS (formerly known as Raspbian).
thanks man its work after 5hour
There is an open issue in github, our developers are actively working on it.
opened 03:24PM - 22 Apr 22 UTC
type/bug
**What happened**:
Did an upgrade to 8.5.0 on openhabian and now grafana-serv… er can't start.
> ● grafana-server.service - Grafana instance
> Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
> Active: failed (Result: exit-code) since Fri 2022-04-22 17:18:48 CEST; 1s ago
> Docs: http://docs.grafana.org
> Process: 7063 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana->server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.plugins=${PLUGINS_DIR} cfg:default.paths.provisioning=${PROVISIONING_CFG_DIR} (code=exited, stat
> Main PID: 7063 (code=exited, status=2)
>Apr 22 17:18:48 openhabian systemd[1]: grafana-server.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
>Apr 22 17:18:48 openhabian systemd[1]: grafana-server.service: Failed with result 'exit-code'.
>Apr 22 17:18:48 openhabian systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
>Apr 22 17:18:48 openhabian systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
>Apr 22 17:18:48 openhabian systemd[1]: Stopped Grafana instance.
>Apr 22 17:18:48 openhabian systemd[1]: grafana-server.service: Start request repeated too quickly.
>Apr 22 17:18:48 openhabian systemd[1]: Failed to start Grafana instance.
**What you expected to happen**:
A smooth upgrade ;).
**How to reproduce it (as minimally and precisely as possible)**:
If I try to restart via `sudo service grafana-server start`, this doesn't work.
**Anything else we need to know?**:
Was working fine with the latest 8.4.X version before the upgrade.
**Environment**:
- Grafana version: 8.5.0
- OS Grafana is installed on: openhabian
I had the same problem. I’ve downgraded to 8.4.7 and everything works ok!
Same error here:
-- Logs begin at Thu 2022-04-28 09:35:36 BST, end at Thu 2022-04-28 09:52:38 BST. --
Apr 28 09:35:50 boba systemd[1]: Started Grafana instance.
Apr 28 09:35:59 boba grafana-server[542]: unexpected fault address 0x27f6b5a
Apr 28 09:35:59 boba grafana-server[542]: fatal error: fault
Apr 28 09:35:59 boba grafana-server[542]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x27f6b5a pc=0x27f6b5a]
Apr 28 09:35:59 boba grafana-server[542]: goroutine 1 [running, locked to thread]:
Apr 28 09:35:59 boba grafana-server[542]: runtime.throw({0x27eb2a9, 0x5})
Apr 28 09:35:59 boba grafana-server[542]: /usr/local/go/src/runtime/panic.go:1198 +0x5c fp=0x5f9bc18 sp=0x5f9bc04 pc=0x5b244
Apr 28 09:35:59 boba grafana-server[542]: runtime.sigpanic()
Apr 28 09:35:59 boba grafana-server[542]: /usr/local/go/src/runtime/signal_unix.go:742 +0x1d0 fp=0x5f9bc30 sp=0x5f9bc18 pc=0x74914
Apr 28 09:35:59 boba grafana-server[542]: runtime: unexpected return pc for github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10 called from 0x9
Apr 28 09:35:59 boba grafana-server[542]: stack: frame={sp:0x5f9bc34, fp:0x5f9bc5c} stack=[0x5f7c000,0x5f9c000)
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bbb4: 0x0005d1a0 <runtime.gwrite+0x00000034> 0x04668d52 0x029efeac 0x00000001
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bbc4: 0x00000001 0x00000000 0x0005da4c <runtime.printstring+0x00000060> 0x00000002
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bbd4: 0x029efeac 0x00000001 0x00000001 0x00000000
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bbe4: 0x00000000 0x0005b450 <runtime.fatalthrow+0x00000044> 0x0005b244 <runtime.throw+0x0000005c> 0x05f9bbf4
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bbf4: 0x0005b468 <runtime.fatalthrow.func1+0x00000000> 0x058000f0 0x0005b244 <runtime.throw+0x0000005c> 0x05f9bc04
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bc04: 0x00074914 <runtime.sigpanic+0x000001d0> 0x05f9bc0c 0x0005b25c <runtime.throw.func1+0x00000000> 0x027eb2a9
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bc14: 0x00000005 0x02092c5c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000002c> 0x027eb2a9 0x00000005
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bc24: 0x059eaf00 0x027f6b5a 0x058000f0 0x02092c5c <github.com/grafana/grafana/pkg/services/alerting/notifiers.init.10+0x0000002c>
Apr 28 09:35:59 boba grafana-server[542]: 0x05f9bc34: <0x00000009 0x05dfa3dc 0x05cb2040 0x059eaf00
Raspbian Linux 10 - ARMv7 Processor rev 3 (v7l) @ 270 bMips, 4 cores
