Failed to start Grafana instance
hey guys, im on raspberry 4 / 4gb all deinstalled grafana and installed again but will not start instance.
Hope, you can help. Thank you :wink:
sudo service grafana-server status
● grafana-server.service - Grafana instance
   Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor p
   Active: failed (Result: exit-code) since Sat 2021-07-31 17:26:46 CEST; 4min 3
     Docs: http://docs.grafana.org
  Process: 18173 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidf
 Main PID: 18173 (code=exited, status=1/FAILURE)
Jul 31 17:26:46 raspberrypi systemd[1]: grafana-server.service: Service RestartS
Jul 31 17:26:46 raspberrypi systemd[1]: grafana-server.service: Scheduled restar
Jul 31 17:26:46 raspberrypi systemd[1]: Stopped Grafana instance.
Jul 31 17:26:46 raspberrypi systemd[1]: grafana-server.service: Start request re
Jul 31 17:26:46 raspberrypi systemd[1]: grafana-server.service: Failed with resu
Jul 31 17:26:46 raspberrypi systemd[1]: Failed to start Grafana instance.
sudo cat /var/log/grafana/grafana.log
t=2021-07-28T14:06:37+0100 lvl=info msg="Starting Grafana" logger=server version=8.0.6 commit=68fe9e3431 branch=HEAD compiled=2021-07-15T08:49:19+0100
t=2021-07-28T14:06:37+0100 lvl=info msg="Config loaded from" logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2021-07-28T14:06:37+0100 lvl=info msg="Config loaded from" logger=settings file=/etc/grafana/grafana.ini
t=2021-07-28T14:06:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.data=/var/lib/grafana"
t=2021-07-28T14:06:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.logs=/var/log/grafana"
t=2021-07-28T14:06:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.plugins=/var/lib/grafana/plugins"
t=2021-07-28T14:06:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
t=2021-07-28T14:06:37+0100 lvl=info msg="Path Home" logger=settings path=/usr/share/grafana
t=2021-07-28T14:06:37+0100 lvl=info msg="Path Data" logger=settings path=/var/lib/grafana
t=2021-07-28T14:06:37+0100 lvl=info msg="Path Logs" logger=settings path=/var/log/grafana
t=2021-07-28T14:06:37+0100 lvl=info msg="Path Plugins" logger=settings path=/var/lib/grafana/plugins
t=2021-07-28T14:06:37+0100 lvl=info msg="Path Provisioning" logger=settings path=/etc/grafana/provisioning
t=2021-07-28T14:06:37+0100 lvl=info msg="App mode production" logger=settings
t=2021-07-28T14:06:37+0100 lvl=info msg="Writing PID file" logger=server path=/var/run/grafana/grafana-server.pid pid=7946
t=2021-07-28T14:06:37+0100 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
t=2021-07-28T14:06:37+0100 lvl=info msg="Creating SQLite database file" logger=sqlstore path=/var/lib/grafana/grafana.db
t=2021-07-28T14:06:37+0100 lvl=info msg="Starting DB migrations" logger=migrator
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create migration_log table"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create user table"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="add unique index user.login"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="add unique index user.email"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_user_login - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_user_email - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Rename table user to user_v1 - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create user table v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_user_login - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_user_email - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="copy data_source v1 to v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Drop old table user_v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Add column help_flags1 to user table"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Update user table charset"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Add last_seen_at column to user"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Add missing user data"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Add is_disabled column to user"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Add index user.login/user.email"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create temp user table v1-7"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_email - v1-7"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_org_id - v1-7"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_code - v1-7"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_status - v1-7"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Update temp_user table charset"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_temp_user_email - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_temp_user_org_id - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_temp_user_code - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_temp_user_status - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Rename table temp_user to temp_user_tmp_qwerty - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create temp_user v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_email - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_org_id - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_code - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_status - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="copy temp_user v1 to v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop temp_user_tmp_qwerty"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Set created for temp users that will otherwise prematurely expire"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create star table"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="add unique index star.user_id_dashboard_id"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create org table v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_org_name - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create org_user table v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_org_user_org_id - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_org_user_org_id_user_id - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Update org table charset"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Update org_user table charset"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Migrate all Read Only Viewers to Viewers"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create dashboard table"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="add index dashboard.account_id"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="add unique index dashboard_account_id_slug"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create dashboard_tag table"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="add unique index dashboard_tag.dasboard_id_term"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_dashboard_tag_dashboard_id_term - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="Rename table dashboard to dashboard_v1 - v1"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create dashboard v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_org_id - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_dashboard_org_id_slug - v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="copy dashboard v1 to v2"
t=2021-07-28T14:06:37+0100 lvl=info msg="Executing migration" logger=migrator id="drop table dashboard_v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="alter dashboard.data to mediumtext v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column updated_by in dashboard - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column created_by in dashboard - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column gnetId in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add index for gnetId in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column plugin_id in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add index for plugin_id in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add index for dashboard_id in dashboard_tag"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update dashboard table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update dashboard_tag table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column folder_id in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column isFolder in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column has_acl in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column uid in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update uid column values in dashboard"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add unique index dashboard_org_id_uid"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Remove unique index org_id_slug"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update dashboard title length"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add unique index for dashboard_org_id_title_folder_id"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create dashboard_provisioning"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Rename table dashboard_provisioning to dashboard_provisioning_tmp_qwerty - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create dashboard_provisioning v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_provisioning_dashboard_id - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_provisioning_dashboard_id_name - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="copy dashboard_provisioning v1 to v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop dashboard_provisioning_tmp_qwerty"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add check_sum column"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add index for dashboard_title"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="delete tags for deleted dashboards"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="delete stars for deleted dashboards"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create data_source table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add index data_source.account_id"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add unique index data_source.account_id_name"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_data_source_account_id - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_data_source_account_id_name - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Rename table data_source to data_source_v1 - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create data_source table v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_data_source_org_id - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_data_source_org_id_name - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="copy data_source v1 to v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Drop old table data_source_v1 #2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column with_credentials"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add secure json data column"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update data_source table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update initial version to 1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add read_only data column"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Migrate logging ds to loki ds"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update json_data with nulls"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add uid column"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update uid value"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add unique index datasource_org_id_uid"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add unique index datasource_org_id_is_default"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create api_key table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add index api_key.account_id"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add index api_key.key"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add index api_key.account_id_name"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_api_key_account_id - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_api_key_key - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_api_key_account_id_name - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Rename table api_key to api_key_v1 - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create api_key table v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_api_key_org_id - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_api_key_key - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_api_key_org_id_name - v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="copy api_key v1 to v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Drop old table api_key_v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update api_key table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add expires to api_key table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create dashboard_snapshot table v4"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop table dashboard_snapshot_v4 #1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create dashboard_snapshot table v5 #2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_dashboard_snapshot_key - v5"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_dashboard_snapshot_delete_key - v5"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_snapshot_user_id - v5"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="alter dashboard_snapshot to mediumtext v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update dashboard_snapshot table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column external_delete_url to dashboard_snapshots table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add encrypted dashboard json column"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Change dashboard_encrypted column to MEDIUMBLOB"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create quota table v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_quota_org_id_user_id_target - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update quota table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create plugin_setting table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_plugin_setting_org_id_plugin_id - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column plugin_version to plugin_settings"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update plugin_setting table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create session table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Drop old table playlist table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Drop old table playlist_item table"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create playlist table v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create playlist item table v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update playlist table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update playlist_item table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop preferences table v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop preferences table v3"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create preferences table v3"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update preferences table charset"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column team_id in preferences"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Update team_id column values in preferences"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create alert table v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add index alert org_id & id "
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add index alert state"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="add index alert dashboard_id"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Create alert_rule_tag table v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add unique index alert_rule_tag.alert_id_tag_id"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_alert_rule_tag_alert_id_tag_id - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Rename table alert_rule_tag to alert_rule_tag_v1 - v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Create alert_rule_tag table v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create index UQE_alert_rule_tag_alert_id_tag_id - Add unique index alert_rule_tag.alert_id_tag_id V2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="copy alert_rule_tag v1 to v2"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="drop table alert_rule_tag_v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="create alert_notification table v1"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column is_default"
t=2021-07-28T14:06:38+0100 lvl=info msg="Executing migration" logger=migrator id="Add column frequency"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add column send_reminder"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add column disable_resolve_message"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="add index alert_notification org_id & name"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Update alert table charset"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Update alert_notification table charset"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="create notification_journal table v1"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="add index notification_journal org_id & alert_id & notifier_id"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="drop alert_notification_journal"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="create alert_notification_state table v1"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="add index alert_notification_state org_id & alert_id & notifier_id"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add for to alert table"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add column uid in alert_notification"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Update uid column values in alert_notification"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add unique index alert_notification_org_id_uid"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Remove unique index org_id_name"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add column secure_settings in alert_notification"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="alter alert.settings to mediumtext"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add non-unique index alert_notification_state_alert_id"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Add non-unique index alert_rule_tag_alert_id"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="Drop old annotation table v4"
t=2021-07-28T14:06:39+0100 lvl=info msg="Executing migration" logger=migrator id="create annotation table v5"
t=2021-07-31T17:26:45+0200 lvl=crit msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: anonymous, data proxy will add X-Grafana-User header with username into the request, default is false.\n"
The log does tell you exactly why it’s not starting - crit (critical) message saying that it cannot parse your grafana.ini
So check and fix the error in that file (around where it says “anonymous, data proxy will add”).
"/etc/grafana/grafana.ini"
thank you!
i changed anonymus= true
but what i have to do with data-proxy?
#################################### Data proxy ###########################
[dataproxy]
# This enables data proxy logging, default is false
;logging = false
# How long the data proxy waits to read the headers of the response before timi$
# This setting also applies to core backend HTTP data sources where query reque$
;timeout = 30
# How long the data proxy waits to establish a TCP connection before timing out$
;dialTimeout = 10
# How many seconds the data proxy waits before sending a keepalive probe reques$
;keep_alive_seconds = 30
# How many seconds the data proxy waits for a successful TLS Handshake before t$
;tls_handshake_timeout_seconds = 10
# How many seconds the data proxy will wait for a server's first response heade$
# fully writing the request headers if the request has an "Expect: 100-continue"
# header. A value of 0 will result in the body being sent immediately, without
# waiting for the server to approve.
;expect_continue_timeout_seconds = 1
# Optionally limits the total number of connections per host, including connect$
# active, and idle states. On limit violation, dials will block.
# A value of zero (0) means no limit.
;max_conns_per_host = 0
# The maximum number of idle connections that Grafana will keep alive.
;max_idle_connections = 100
# The maximum number of idle connections per host that Grafana will keep alive.
;max_idle_connections_per_host = 2
# How many seconds the data proxy keeps an idle connection open before timing o$
;idle_conn_timeout_seconds = 90
# If enabled and user is not
anonymous, data proxy will add X-Grafana-User header with username into the req$
;send_user_header = true
thank you!
I trust that you spelled it “anonymous”?
Now that you have made those changes, what remaining errors do you get when
you start Grafana?
Antony.
heheee, yep anonymous is true :wink:
Grafana not starting!
sudo systemctl status grafana-server
   Active: failed (Result: exit-code) since Sun 2021-08-01 13:54:56 CEST; 9s ago
  Process: 29654 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidf
 Main PID: 29654 (code=exited, status=1/FAILURE)
Aug 01 13:54:55 raspberrypi systemd[1]: grafana-server.service: Service RestartS
Aug 01 13:54:56 raspberrypi systemd[1]: grafana-server.service: Scheduled restar
Aug 01 13:54:56 raspberrypi systemd[1]: Stopped Grafana instance.
Aug 01 13:54:56 raspberrypi systemd[1]: grafana-server.service: Start request re
Aug 01 13:54:56 raspberrypi systemd[1]: grafana-server.service: Failed with resu
Aug 01 13:54:56 raspberrypi systemd[1]: ***Failed to start Grafana instance.***
no proxy in my network! Are the ini with the default “data proxy” settings ok?
thank you
You have a newline in your .ini file that should not be there. Lines starting with a # or ‘;’ are treated as comments and are ignored, so the lines should look like this:
# If enabled and user is not anonymous, data proxy will add X-Grafana-User header with username into the req$
But you have a newline part way through the comment so it is invalid, like this:
Remove the newline so the comment is back on one single line starting with ‘#’
hey guys thank you.
the problem was an old grafana installation and under /etc/grafana/ a lot of files was not deleted like grafana.ini … after deinstallation.
sudo apt-get --purge remove grafana
sudo apt-get remove --auto-remove grafana
so the old ini file was there but not the new one after installation.
thank you guys so much
