Sending graphs as email
Hello
I would like to send grafana dashboards as email from our environment.
We are using non commercial version and installing using the manual installation. My servers does not have internet connection.
Is that possible?
Can i use image rendering plugin and install manually using non-commercial version?
BR
Thanks
Burcu
You can use this plugin with open source version of Grafana to generate PDF from dashboard
