What Grafana version are you using?
Im using Grafana 7.5.11 and influxDB 2.0 -
I have two timeseries. The first one contains data about the mass of the produced product and the other contains data about the machine status. I want to post the value of the first timeseries but only if the second timeseries shows a certain value. -
I tried to apply the following query:
Select mean(“tag1”)
FROM(
SELECT distinct(“Mass”) as “tag1” FROM “Measurement” WHERE $timeFilter GROUP BY time(1m) fill(previous)
SELECT distinct(“Status”) as “tag2” FROM “W_UHT-1” WHERE $timeFilter GROUP BY time(1m) fill(previous)
Where (“tag2”=1) and $timeFilter GROUP BY time(1m) fill(previous) -
What happened?
The query resulted in no data
Is there a way to achive my goal?
