Hey Guys,
im an absolut beginner in grafana.
I’ve got a tank being monitored.
Via Grafana I get the curve displayed and can see when it was emptied.
Now I would like to display the time in a separate panel until the tank has filled up to 50% again.
My idea was this:
IF (SELECT mean(“payload_fields_data_analog”) FROM “mqtt_consumer” < 15.000L)
(SELECT mean("payload_fields_data_analog") FROM "mqtt_consumer";
else{
return 0;
15.000L is the half volume.
Thats the Code in c, the way I figured it would be.
Is it possible to write something like that in the query?
Thanks for your help ![]()
