Sample query for Pi chart from Azure data explorer data source
Can I get sample query for reference , I need to make Pi chart to show health of service over the time ( like for last one hour, one day, one week etc.) where the Up & Down % will be shown on the Pi chart.
The data in ADX will have columns: health status & time stamp
    Latest version
    Pi chart for service health status
    Using Panel configuration and data query
  • What happened?
    Not able to find the exact configuration
    Pi chart showing the % of up and down status of a service over the time
    No
    Not getting expected output
Hi @anishpk123
I do not use the Azure Data source so cannot tell how to write queries.
However, I found some good reference that explains the steps on how to use Azure Data Explorer and create some Dashboard panels.
Here is the link to the original documentation at our website. Also, found both (documentation and a video tutorial) from the web.
I hope this helps and hopefully other community members can provide more information to your question.
